Mike, K6AER,
I need to be brief here....but I think I have the answers you seek. (hopefully)
And, to be clear, I love Kenny!
I think he is doing great!
I wish him much continued success!
He designed these amps (Merc IIIs and Lux) and builds them here in Florida! (I have no idea who wrote the software/firmware).
But I do know who/where designs and builds the hardware, and's that Kenny and his crew in Miami!But, neither the Mercury IIIs nor the Lux have much (if any) headroom, neither are clean enough for me, nor are either "brick-on-the-key" amps....so, going from an Alpha to a Lux, would be a hard voyage!
1) BTW, Mike....I think you (and many others looking at modern HF LDMOS amateur amps) may be under the impression that the Lux (or the RF-Kit 2K, etc.) has two modules? They do not.
They have one module, with two devices on it...
(and that is not the same as having a tube amp with two 8877's or two 4cx1500b's, or two 3-500z's versus amps with only one of these)....
So, while the marketing side can say the amp has twice the amount of device dissipation as an amp with only one of these devices, they have to do something with the HEAT that comes out of these devices in such a small space! And, do something with the combiner heat, filter heat, etc.
As well as have a power supply that could handle the device DC power needed in order to fully utilize two devices. As well as have some sort of linearity at some specified output.
2) Mike, the short answer you seek, is:
The Max Output of the Mercury Lux is ~ 1500 watts, assuming good VSWR and not going past the max time in transmit spec....not any "headroom" at all!3) The long answer(s) in three parts....
a) the absolute Max RF Output of the Lux (like most amateur amps) is its Power-Supply-Limited output....according to the manual, the Lux Power Supply "faults-out" at 45 amps....so, 45 amps at approx 53.6vdc = 2412 watts DC input, times 60% efficiency = 1447 watts RF out...and, while I see > 65% to 68% plate eff in Class AB with 8877's, I'm not sure any modern LDMOS HF amp is that efficient....but, even if you think the Lux and/or RF-Kit-2K is that eff, 65% would only yield ~ 1569 watts RF out.
So, it looks like the Lux is "power-supply-limited" to ~ 1500 watts out.b) "Heat-Dissipation-Limited" output...and, this (here again, like in most amateur amps), is mode/duty-cycle dependent....and, as I have mentioned a while back (and Jim highlights here), there is a LOT of heat in a very small space that needs to be dissipated....
LU6PSG nailed it. The 188 (and 189) devices are split into 2 x halves...(and each half consists of paralleled multiple mosfets...and if just one tiny mosfet fails shorted, the entire device is toast). On the merc-3, only one 189 device is used and only one splitter/ combiner is required. On the LUX (and B26 german amp), they paralleled the 2 x halves of each device into one big MOSFET. One device is push, the other pull. Done that way so only one combiner is required. The alternative would have been to use a combiner for each device, and each device operating in PP. Then a high powered combiner, to combine the outputs of the pair of smaller combiners. To pull this off, a splitter would be required, then 2 x more splitters.
Installing 2 x devices onto the same heatsink, with 1" between them, defeats the overall heatsink capability. (the devices cook each other). To really do it right, each device should be on it's own, separate heatsink. Yaesu did that on it's FT-1000D, and used interlaced heatsink fins. Harris also did the same on it's SS ch-2 TV TX pa's..that are now available surplus ( and being modified for 6M use). Same deal, interlaced heatsink fins. That mess is formed into a 4 x sided tunnel ram, with air being blown from one end.
Not quoting complete IMD specs from IMD3 to IMD21 (at rated max power) is reprehensible at best. What are they trying to hide ? Bragging about harmonic suppression instead... is a moot point at best.
So, it looks like (according to the manual) the "Heat-Dissipation-Limited" output is ~ 1500 watts SSB, and "maybe" 1500 CW, and 800 watts FT-8 / RTTY.c) "Linearity-Limited" output, of course is moot on CW....but on SSB, this number is a moving target that depends on what you consider "linear enough"....And, while having a second device on the board (versus the Mercury IIIs) might lead some to think the linearity of the Lux is substantially better, but I have yet to see that.
But, even if the Lux is better, I suspect that finding the output that doesn't negatively contribute to your station's IMD above that of your exciter / transceiver IMD output, will be disappointing!
Of course, this depends on what exciter/transceiver you're using, but since just about every modern "transceiver" is worse than most of the tube amps, with some / many (?) of our modern rigs being better than most modern SS amps (LDMOS, or not)....
My guess is, most will find the "linearity-Limited" output of the Lux to be < 1000 watts, probably closer to ~ 800 watts or so....again, this depends on your definition of what is "linear enough" and what exciter/transceiver you're driving it with...
(Goodness help us when someone cranks up a '101D/MP up to the top of the ALC scale, and then drives these poor LDMOS amps to 1500 watts out...Ugh!)
Mike, hope that answers your question? (~ 1500 watts)
John, KA4WJA
