Makes me like my 930 even more
Thanks all
Collins 32S3 transmitter
radio run into a dummy load with a flat SWR
tested both 6146's to be good
will check or replace coupling cap
there is no HV meter on the radio the power supply was rebuilt when I purchased it
I will check the screen voltage at the tube sockets. there is a resistor in series in the screen supply line, will check that
Someone redid the power supply connector and loaded some of the pins with excess solder, had a tough time getting the mating connector on. Would like to replace both connectors in the future, not an easy task.
