Author Topic: injector noise F150 in Ft 891 hf Help  (Read 154 times)
N3VET
« on: December 12, 2022, 05:35:09 PM »
in stalled my Ft-891 hf  with Atas 120  on my  F-150 echo boost engine.  running i hear the injectors  threw my radio
 s9 noise level 40 m band , tried grounding with ground straps  with no change ..
  has any  seen this  or able to solve  this type of  noise  .
thank you 73 Bruce N3VET
Re: injector noise F150 in Ft 891 hf Help
« Reply #1 on: December 12, 2022, 06:03:36 PM »
You can try some snap on chokes Mix 31 over the injector wires if there are any you can get to. Also make sure hood is bonded at 2 edges (back edges obviously), make sure the exhaust pipe is bonded at least 3 locations along its length. You can use large SS hose clamps for the exhaust pipe end, and use stainless screws and star washers all coated in No-Ox-Id on the chassis end. Keep all bonding straps as short as possible.
K4RKX
« Reply #2 on: December 13, 2022, 07:04:39 PM »
I don't want to say im glad im not the only one that has engine sounds coming into my brand new ft891 but i thought about getting a rfi kit from palomar engineering  for the radio.  I have a 2007 honda accord so I have engine, injector, modules from cars computer i guess , all going into my ft891. the only time i can hear decent is with the ignition off.
WA3SKN
« Reply #3 on: December 14, 2022, 09:56:52 AM »
Welcome to HF mobile!
Have you contacted Ford about this?  A LOT of Ford products are used by Govt with radios and the vehicles need filtering. They may have a kit.
-Mike.
