Hi Paul,
I'm about one step above being a rookie so this will help you get started then your on your own ! Bring up the site and looking at the screen just above the "green box", you will see the words, "skip and go directly to the main page". Click on the words "main page". The next page will show a world map as a "gray line" along with the "bands of operation" . Say for example you want to be spotted on 40 mtrs then click on the 40 mtr box . Then look a little lower and to the right and you will see the words "spotted call sign" . Type your call sign on this line. Then start sending your CQ or CQ Test with your call sign like you were actually trying to make a contact. Sit back and wait for a few minutes and if anyone has spotted you, the new info will be displayed where originally was blank. Keep in mind if you try it again on the same band it won't work for about 10 minutes, guess it does a reset ! This afternoon I tried both 40 and 20 mtrs with NO replies but after running the "reverse beacon", plenty of stations replied with good S/N reports . So guess at that time, NO one was close enough to hear my 25 watts of power Hi Hi Hope this will be helpful for you, Mike W9KY
