Author Topic: FT-4 not logging  (Read 177 times)
KD0PO
FT-4 not logging
« on: December 16, 2022, 09:03:37 AM »
when I make a FT-4 QSO and get RR73 my WSJT-X doesn't prompt to log, it just calls the other station again from the beginning???
What am I doing wrong??
Ver: 2.5.4
thanks
Re: FT-4 not logging
« Reply #1 on: December 16, 2022, 10:28:32 AM »
Go into settings, the reporting, and check the box "Prompt me to log QSO"
KD0PO
« Reply #2 on: December 16, 2022, 02:22:24 PM »
That is checked. When I am in FT-8 it works perfectly.
I only have this problem in FT-4.
Ray
« Reply #3 on: December 16, 2022, 07:25:50 PM »
That is interesting.  It works fine for me in FT4 like that.  Done it in quite a few FT4 contests.  Not sure what the problem might be then.
KD0PO
« Reply #4 on: December 17, 2022, 04:42:22 AM »
thanks for your reply.
I have it loaded on anouther computer and get the same result..
Ray
KD0PO
« Reply #5 on: December 17, 2022, 06:29:09 AM »
I re-installed ver 2.5.3 and everything works as it should.
I guess my copy of 2.5.4 has a problem.
the Princeton web site is down??
Thanks again
73 Ray
K0RS
« Reply #6 on: December 17, 2022, 10:16:48 AM »
Hmm.  I'm using 2.5.4 and it works OK.  Maybe corrupted during the download?
"90% of the people in a pile-up have no idea what's going on.  It's up to you to be in the remaining 10%."  *W9KNI*
« Reply #7 on: December 17, 2022, 01:18:49 PM »
I am also using Version 2.5.4 and it works like it should for me also.
Did the FT8 contest a couple of weeks ago using FT4 and had the program log for me, where it prompted me to log after each QSO.
