Hi,
I've been trying to fix a EB27A based amplifier, that is a 28V 2x MRF422
https://www.communication-concepts.com/eb27a-1/The owner told me that it was working and suddenly a 10uf 63v capacitor on the board where the 28V goes in, blew.
So, I checked the transistors and they where dead. I had to replace the LM723 regulator and the trimpot in the BIAS circuit because they were also bad. I checked many other parts and were fine.
So far so good, all power supply voltages where on the spot, BIAS regulation performed without replacement transistors as indicated on the constructions hints pdf (with a 33 ohm resistor between base and emitter pads, 0,5V).
Then, I soldered the new transistors, PTT, 3w input carrier and puff. They died on the spot.
I am kind of lost right now, everything else seems to be just fine.
I would really appreciate any help. Thanks for reading.
73 de Guido LU8EQ
