Author Topic: Can I trust used equipment? Trying to build a manpack.  (Read 308 times)
KF0AGC
Re: Can I trust used equipment? Trying to build a manpack.
« Reply #15 on: December 22, 2022, 12:39:47 PM »
Received Signal                                          -144.57   dBm
Received Signal                                           0.01           μV
Fade Margin                                               -31.55      db
You need a much stronger signal than 0.01uV, that is not workable. 2 to 3uV is probably the very minimum workable signal for regular contacts, you need a margin to allow for fading (it happens on VHF) and to allow for QRN from electrical devices, etc.
73 Dave
Got it.  I'll play around with it and see if I can get a combination up in that range.  Thanks
« Reply #16 on: December 22, 2022, 12:54:02 PM »
I had an elaborate 2M setup.  I'd mount a 12V rotator on a roof rack.  A 2M beam gave me plenty of gain.
I did well with 25 watts with SSB on a hilltop but  170 watts worked even better.
I ran 10 watts during contests.  While I had competitive scores it wasn't always easy to make contacts.
Zak W1VT
