For the past many months, I had a noise problem on 10, 12 and 15 meters that grew increasingly worse over time. After I eliminated potential noise sources in the house, I noticed that the noise disappeared when it rained and always came back after a day of dry weather. So, I figured it was likely a nearby line problem. The noise as heard on a receiver didn't have a 60 Hz component, but rather sounded like something frying in a skillet. And the intensity varied quite a bit across the 10 meter band, with a distinct null appearing every 100 kHz or so. I had also used a portable radio tuned to 28 mHz and held it up to the ground wire coming down the pole on several poles on the street and the noise increased substantially as the radio approached the ground wires.
I reported the problem to the local power co-op and they showed up today to check out the line hardware. They found a defective lightning arrestor about 200 yards down the road and replacing it was just a 5 minute job. They brought the defective arrestor to me and explained the problem. The arrestor had a ceramic body, maybe 4" in diameter and 15-18 inches long. The unit had several cracks over that length. These units had been sourced from China and the guy said they'd had a lot of similar failures with them. He then showed me what they replaced it with and the new arrestors had a polymer body with the consistency of rubber and no ceramic material. When I checked the bands, the noise was completely gone.
If you ever have a line noise problem like this, it is helpful if you can do anything to help pinpoint the problem (beam heading, etc.) and if you know if the problem disappears or is less when it rains. The noise can propagate a long way down the line, so it can be difficult or impossible to pinpoint with your beam, but in my case there was a slight peak in the noise in the direction of the problem pole. When contacting the power company, I started with their director of communications and he just happened to be studying for his ham license and so was sympathetic to the problem.
73, K8AC
