Doublets of just about any length can be fed with twinlead
or open wire line and made to work. The length affects the
efficiency and radiation patterns, as well as the impedance
that the tuner has to match on each band. Just a matter
of choosing a convenient combination that fits your available
space and meets your needs.
Besides
W4RNL's 88' doublet (the length of which was chosen
so the radiation pattern is broadside to the antenna on 80m
through 20m), another doublet of similar length is the
ZS6BKW,
where the dimensions were chosen to give a relatively low
SWR on 40, 20, 17, 12, and 10m.
Note that in either case, both the length of the antenna
and the feedline affect the impedance that the tuner has
to match. Sometimes you end up with a combination that
doesn't match easily on one or more bands, in which case
changing the feedline length by a few feet may fix it.
