Author Topic: Kenwood ts-820S problem: meter jumps when "unkey"  (Read 239 times)
W1JPP
Re: Kenwood ts-820S problem: meter jumps when "unkey"
« Reply #15 on: December 26, 2022, 05:01:47 PM »
Ok.
I’ll start with cleaning the relays.
I don’t have a keyer and I’ve always tuned up - this rig, my 520 and 520s by turning the switch to cw and flipping the send switch for a few seconds while I adjust the plate and load.
So maybe there is something in the cw key switch.
« Reply #16 on: December 27, 2022, 02:31:04 AM »
Ok.
When you get back to the original problem, since D20 checked out, the next thing to check is the T/R relay. The ALC signal switches through one of its set of contacts. Gentle cleaning (isopropyl alcohol and copier paper) may help -  otherwise replace it.
W1JPP
« Reply #17 on: December 27, 2022, 07:26:44 AM »
If you have a key plugged into the key jack, the key must be closed (shorted) for there to be a CW carrier. If you don't have a key in the jack, it will not develop a carrier if the internal shorting switch in the jack is dirty.
well that was exactly it - I dont have a cw key - but when I looked in the back inside of the radio, where a key would plug it from the outside, I noticed that there is a bracket that holds the contact and it was broken - the contact was floating, no ground...if I held the contact as it should be, had the rig in cw mode, and flipped send, then I would see the power out on my meter...
and I cleaned the contacts on the two relays (antenna relay and transmit/aux relay) and that seems to have cured the meter spike issue I was having. when i unkeyed...
so now my only remaining issue is, after I cleaned the IF board contacts, and plugged it all back in...I have no S meter deflection when listening...if I'm tuning up, or speaking, the meter deflects but just listening it sits at zero...I'm receiving fine...If I compare it to another rig, same antenna and do a/b tests, the strength of the sound sounds the same, and I receive the same weak signals...and that was happening before I cleaned the relays, but just after I pulled the IF board...so I suspect I dont have the connections right on the IF board???
But I'm not sure I have the connections in correctly....if you see the pics, you can see I have two remaining pins...
https://www.dropbox.com/home/hf%20radio/if%20board%20pins
I think I have it right, as I'm not sure how else it could be configured...
« Reply #18 on: December 27, 2022, 07:40:54 AM »
Your picture is protected so it requires a log-in.
W1JPP
« Reply #19 on: December 27, 2022, 10:15:30 AM »
I’ll check it. Usually if you just close the login screen the pics will appear
