Author Topic: FT8 not transmitting on even sequence  (Read 265 times)
KE4YD
« on: December 24, 2022, 05:51:09 PM »
When using F/H mode FT8 will not transmit on the even sequence. I can't check the tx even/1st box because it is greyed out.
Any ideas or suggestions.
David KE4YD
WA9AFM
Re: FT8 not transmitting on even sequence
« Reply #1 on: December 24, 2022, 05:56:14 PM »
That's a normal configuration in 'F/H'.
« Reply #2 on: December 24, 2022, 06:04:49 PM »
David KE4YD
Yep, you are correct. The Fox always transmits even, The Hound is always odd.
By the way, the Crozet expedition is not using F/H
KE4YD
« Reply #3 on: December 24, 2022, 06:20:57 PM »
OK That explains it.
Thanks guys,
David  KE4YD
