I know quite a few hams hiding in their attics, and most have this the same problem. We have found two main culprits, and it has nothing to do with a choke.
1. I assume your attic space is being used distribute your house electrical wiring, and if like around here, also has your HVAC blower and heat exchanger located up in the attic. Is that you? If so, very good chance your antenna is just to close and picking up noise from the wiring and HVAC systems in your attic. Really simple to test, turn the power off at your main breaker, and power your radio from a 12-volt battery. If the noise goes away, you are the source of the noise, and no ham foolery choke will fix it.
2. If you tried to ground anything, get rid of it because it is wrong. With an attic antenna you have no need for any grounding other than the AC ground in your DC power supply. So, remove anything you might have added.
Do those two things, and you will find your problem.
