The procedure to find the offending device(s) in your home is:
Switch circuit breakers OFF/ON to find out which room the device is in.
With the power to that room on, unplug devices in that room one at a time to find the RF noise source.
You might find several sources. RFI can be like peeling an onion; remove one RF source and the next lower one is revealed. You might want to check all bands carefully, record the S-meter readings and get to work. After fixing one noise source you can look for others. Enjoy!
In my small house I located eight RFI sources.
Water catchment UV lamp water treatment: wrapped the AC cord around an FT240-31 ferrite. Fixed.
Four USB charger wall warts: replaced with a different brand. Fixed.
Two ceiling fan lamps: leave lights off when operating. Fixed.
Router: Wrapped the Ethernet cables 12 times through an FT240-31 core. Wrapped the DC cable 12 times through an FT240-31 core Fixed.
