Looks like suggestions are for a low SWR antenna that will stand 100 years!
I thought we were discussing a wire hanging from a
telescoping fishing pole.
...The total length of the wire need to be > 3/8 wave for the longest band...
Not if you want an effective radiation pattern on twice
that frequency or higher, like an antenna to work
10 / 15 / 20m.
A 3/4 wave vertical is a bit down from 5/8 wave, but
still generally usable without too much loss. But as
it gets longer, more of the radiation is at high angles,
which aren't useful on 10m. With a 1-wavelength
vertical on 10m (1/2 wave on 20m, which meets
your criteria for length) most of the radiation is at
higher angles that generally aren't going to support
ionospheric propagation.
Personally for my portable operations, I find it easier
to use a pre-tuned wire antenna that doesn't need a
tuner. But partly that is because my QRP rigs
often don't have an internal tuner (or even an SWR
meter in some cases), and it is too much bother and
extra weight to bring one along.
But that's a matter of personal preference.
