Rino,
In addition to K9LA's article, I have a friend who has his 80m (80m/160m) vertical in a tree and it does work well for him.
I plan to install a vertical for 80 m, but it would be among trees (spruces and pins)
to be more specific, there will be trees all around, the closest ones about 4 feet.
I wonder how it will affect my vertical, maybe it won't ?
My friend Bob, KC4VO, describes his antenna in detail on his qrz page.
https://www.qrz.com/db/KC4VOIn brief...he has a 47' vertical, with base loading (or sometimes he extends it to a full 64' height) in a 36' tall magnolia tree....(thereby leaving at least the top 11' exposed and in the clear)....fed against many (90?) ground radials.
He is about 130 miles from me, so his 80m signal from his vertical is much lower (15 - 20db) than others in our area (within 200 - 250 miles) using horizontal dipoles....but when we are talking with other friends up North (WI, PA, NY, NJ, NH, etc.) he is always stronger up there, than the rest of us! (and when we talk to some friends in Europe, here again he is always stronger than those with the dipoles)
Although sometimes he does "extend" the vertical to full height of ~ 65', and of course bypasses the base loading, and he picks up some additional gain...and, while you'd not think to be noticeable, for us close-by here in Florida its usually about a 2db increase, and for those up north or in EU it's even more...
Have a look at what he has.
https://www.qrz.com/db/KC4VOHope this helps.
John, KA4WJA
