Pages: [1] 2 3 4 5 6   Go Down
Author Topic: TN8N - CONGO  (Read 2154 times)
VE3VEE
TN8N - CONGO
« on: January 06, 2023, 01:08:17 PM »
Started few hours ago on 14.025. They are 599+25dB, but that is to be expected from this team of Czech operators.
8 operators: OK1BOA OK1FCJ OK1CRM OK1GK OK2ZA OK2ZC OK2ZI OK6DJ
9 radios
More info: https://www.qrz.com/db/TN8K
Marvin VE3VEE
EI2GLB
Re: TN8N - CONGO
« Reply #1 on: January 06, 2023, 01:50:59 PM »
Not needed here will try for 1 Q for a Marathon point,
Re: TN8N - CONGO
« Reply #2 on: January 06, 2023, 03:21:17 PM »
Ditto. Barring a magical opening on 6m I'm good from 10-160, all three modes. Might fill in a greenie or two on FT8.
K0AP
Re: TN8N - CONGO
« Reply #3 on: January 06, 2023, 04:38:15 PM »
9 radios
Marvin VE3VEE
BTW, the call sign is TN8K not TN8N...
73 Dragan K0AP
VE9VIC
Re: TN8N - CONGO
« Reply #4 on: January 06, 2023, 04:43:28 PM »
Same here, 1 qso for a Marathon point and to test a new home made vertical.
N2SR
Re: TN8N - CONGO
« Reply #5 on: January 06, 2023, 04:55:15 PM »
Easily worked on 20 cw earlier this afternoon.
Not needed, but don't have it confirmed on 20 cw.
Sitting this one out for the most part.
Elect a clown.  Expect a circus.
VE3VEE
Re: TN8N - CONGO
« Reply #6 on: January 06, 2023, 05:46:44 PM »
73 Dragan K0AP
Hi Dragan,
Thanks for noticing my typo.
If a moderator reads this, please edit the title to read: "TN8K - CONGO"
Marvin VE3VEE
KC2SST
Re: TN8N - CONGO
« Reply #7 on: January 06, 2023, 06:51:55 PM »
A few band fills would be nice.  But with  Crozet and Bouvet, I wonder, is it possible to OD on the sweet, sweet DX?
Re: TN8N - CONGO
« Reply #8 on: January 06, 2023, 08:45:59 PM »
Managed to snag them on 30 and 20 tonite, They are ATNO for me.  Tried on 160 meters but joy so far.
KE8KMX
Re: TN8N - CONGO
« Reply #9 on: January 07, 2023, 04:22:46 AM »
ET3AA  - Ethiopia  is coming up as well.  Will be a new one for me hopefully.
Gino - KE8KMX
Re: TN8N - CONGO
« Reply #10 on: January 07, 2023, 08:46:47 AM »
Congrats on the new one James!  I can use them on 30 and below.  Have them worked 20-10 meters.
K0RS
Re: TN8N - CONGO
« Reply #11 on: January 07, 2023, 08:56:52 AM »
Note that when in FT8 they will be transmitting in normal mode, multi-stream. No F/H expected.
"90% of the people in a pile-up have no idea what's going on.  It's up to you to be in the remaining 10%."  *W9KNI*
VE3VEE
Re: TN8N - CONGO
« Reply #12 on: January 07, 2023, 11:03:52 AM »
Yes, before calling them yesterday, I first observed if there were any stations successfully completing their QSOs above +1000 without moving down. Many stations were still using Fox/Hound, but some stations completed their QSOs without changing their TX frequency. It looks like MSHV may be becoming the favourite of the very recent DXpeditions (TN8K, FT8WW, T33T, etc).
Marvin VE3VEE
N4UFO
Re: TN8N - CONGO
« Reply #13 on: January 07, 2023, 04:13:47 PM »
The problem with F/H is you move down and then are covered up by people calling on their spot in the waterfall. Can't remember which, but one DXpedition I used F/H and would get a reply, then no RR73. Happened twice. Finally turned off F/H and bam! Got an RR73 in one call.
In short, it was a good idea. But it depends on callers that are educated and follow the plan. Too many are not.
KM4SII
Re: TN8N - CONGO
« Reply #14 on: January 07, 2023, 07:50:44 PM »
Loud and easy on both 30 FT8 and 40 CW this evening. Both are new bands for me as I only worked TN5R on 20, 17, and 15m back in 2018.
Mason - KM4SII
Pages: [1] 2 3 4 5 6   Go Up
