Author Topic: Yaesu G-1000DXA Slow CCW rotation  (Read 246 times)
K0RO
« on: January 06, 2023, 04:10:22 PM »
My G-1000 rotates at normal speed clockwise but at half speed counter-clockwise.  Voltage on motor lines read 29 VDC clockwise and -11 VDC counter-clockwise.  Voltages should be equal but opposite in polarity.
Controller was sent to Yaesu but they find no problem with it.  It drives their test-bench rotor properly in both directions.  Voltages are nominal.  And a test of the rotor on the tower powered by my shack power supply without the controller shows proper rotation speed in both directions.
Any ideas?
Ralph Bolt, KØRO
KB7TT
Re: Yaesu G-1000DXA Slow CCW rotation
« Reply #1 on: January 06, 2023, 04:56:18 PM »
Flakey connection on a wire????
K6AER
« Reply #2 on: January 06, 2023, 06:36:59 PM »
If the voltage out of the controller is correct then you have a bad cable connection to the rotor.
K6AER
« Reply #3 on: January 06, 2023, 06:59:15 PM »
Also check the reverse polarity diode on the rotor switch.
W1AN
« Reply #4 on: January 07, 2023, 07:57:21 AM »
Ralph, You will need to check for past water caused corrosion on the cable connector or on the rotor connector itself.  The corrosion could provide a signal path to terminal 6 from your CCW voltage. This may cause the controller to go to slow speed. Although auto slow speed limit switches are not used on the G-1000DXA, I believe the controller uses the same circuit board as the G-2800DXA.  Disconnecting pin 6 at the controller end may confirm. Checking for a voltage change at terminal 6 as you change from CW to CCW could also confirm.
John W1AN
K0RO
« Reply #5 on: January 07, 2023, 09:40:12 AM »
Thanks guys.  I appreciate the responses.  I intend to follow each suggestion as I search for the problem.  I'll post my findings.
Ralph Bolt, KØRO
