Randy,
Unless you have some pretty hearty squirrels, maybe you have some imitation LMR cable?
Are you sure you have Times Microwave LMR-400? Or is it LMR-400uf? Or LMR-400-pvc? Or is it imitation LMR-400, of some kind?
The reasons I ask are:
--- actual LMR-400 (and Davis Bury-Flex) has a stiff/smooth PE (polyethylene) outer jacket....and, I've found my squirrels will gladly chew on PVC jacketed cable (like RG-213/214, etc.) but they avoid gnawing on my PE-jacketed Davis Bury-Flex. (and, this has been the case now for more than a decade)
--- actual LMR-400db has the same PE jacket, along with the flooding-compound-gel inside (which does a good job of keeping water out, when the jacket is pierced....and, has the additional advantage that critters don't like the taste and/or it sticks to their teeth, etc....so, they stop chewing on the cable quickly)
--- LMR-pvc has (obviously) a PVC jacket and is loved by squirrels.
--- LMR-400uf has a thremoplastic-rubber jacket (and, I'm not certain how that tastes to squirrels)
--- imitation LMR-400 could have any jacket...
The solution to many hams' problems with low-loss flexible cables, that they need to keep critters from chewing is using Davis Bury-Flex, as it has a stranded-center-conductor (like LMR-400uf), but also has a stiff/smooth PE outer jacket (like real LMR-400 has)....
Just saying, have a close look at what cable you have and what cable you're thinking of buying to replace it with...
And, while I understand your concerns over "barrel connectors", if you use a real Amphenol (or KIngs) brand PL-258, they should handle a few KW on 75m with no problem....imitation Amphenol, no-name-brand, etc., I wouldn't trust in ANY situation!
Remember, you do get what you pay for.
Hope I helped?
John, KA4WJA
