Is anyone running dx cluster client "xdx" on a Raspberry Pi, and if so, were you able to configure it to play a sound when a spot arrives?
Beeps are enabled at the node with the SET/BEEP command but despite trying several different values in xdx's sound configuration I've had no luck getting beeps. Other apps on the Pi generate sound as expected. Any suggestions appreciated.
