Author Topic: xdx on Raspberry Pi - sound configuration?  (Read 83 times)
VE3VSM
« on: January 13, 2023, 03:58:24 PM »
Is anyone running dx cluster client "xdx" on a Raspberry Pi, and if so, were you able to configure it to play a sound when a spot arrives?
Beeps are enabled at the node with the SET/BEEP command but despite trying several different values in xdx's sound configuration I've had no luck getting beeps.  Other apps on the Pi generate sound as expected.  Any suggestions appreciated.
