Home
Help
Search
eHam
eHam Forums
Amplifiers
ALC QUESTION
« previous
next »
Pages: [
1
Go Down
Author
Topic: ALC QUESTION (Read 410 times)
N3VET
ALC QUESTION
on:
January 15, 2023, 04:41:44 PM »
is it necessary to use the ALC between an SB 200 amplifier and a yaesu FTDX 10 .. some say its not needed
thank you Bruce n3vet
K0CWO
Re: ALC QUESTION
Reply #1 on:
January 15, 2023, 04:55:31 PM »
It is not.
73, k0cwo
AE0Q
Re: ALC QUESTION
Reply #2 on:
January 15, 2023, 05:56:20 PM »
Solid-state radios have a built-in ALC to control their transmit levels. Don't connect the ALC from the amp.
The amplifier ALC feedback to the radio was sort of useful with tube transmitters, although a pain to adjust (could change from band to band).
NSGA Edzell 1974-77 CTM2 GM5BKC : NSGA Rota 1972-74 ZB2WZ, SV0WY
https://radioandtravels.blogspot.com/
http://www.qsl.net/ae0q/
HB9PJT
Re: ALC QUESTION
Reply #3 on:
January 16, 2023, 12:26:13 AM »
The ALC helps to protect the amplifier. For example, if the impedance of the antenna is suddenly higher, the ALC voltage rises from the PA and regulates the transmit power of the TRX back.
73, Peter - HB9PJT
K9CTB
Re: ALC QUESTION
Reply #4 on:
January 16, 2023, 07:27:45 AM »
Agree with AE0Q and others ... I was taught the same thing by Radio Dan, a Henry expert I highly recommend (I'm using an old Henry dual 3-500Z amp here).
Pages: [
1
Go Up
« previous
next »
eHam
eHam Forums
Amplifiers
ALC QUESTION
