Author Topic: Kenwood antenna tuner relay help  (Read 108 times)
WB8PFZ
« on: January 16, 2023, 06:14:00 AM »
I purchased a beyond repair 930 with the built in antenna tuner. I could use the tuner for another radio. The relay Kenwood part number is S51-2408-05. It is located next to the motors that drive the caps. The relay in mine is missing the cover with the part number . The relay is broke. Thanks Mike
WB8PFZ
Re: Kenwood antenna tuner relay help
« Reply #1 on: January 16, 2023, 07:18:31 AM »
The relay has marking on the body of 28X2D3.
WB8PFZ
« Reply #2 on: January 21, 2023, 11:15:24 AM »
Omron G2V-2    now if I could find one.
AB4ZT
WB8PFZ
« Reply #4 on: January 22, 2023, 05:22:28 AM »
The one I need is a 12 volt. I find all the voltages but 12 volt. I believe the G2V series has been replaced by the G5V series that Mouser carries. Next time I place an order I will try one of those. The tuner works but would like to replace the relay that is a little mangled. Thanks Mike
