Also he appears to be using steel cable, which is likely to be somewhat lossy at hf.
And a separate DC cable to operate the motor, when he could have run the DC up the coax. Adds to the users installation cost.
Using weights to extend the wires means it will only work in an inverted Vee configuration, not as a straight dipole. Have to be some weights to hold the wire up for 80m, and this is only really useful to broadband 80/75. Otherwise just run a fan.
