My understanding of multiband trap antennas is that a trap will pass signals to lower bands but not higher bands. In other words if the 30m trap became damaged then I'd have problems on 40m and 80m as well, but I don't. 20, 15 and 10m are unaffected.
Hey Ken! Long time! How are things? Still overseas or back in NA? I moved cross country and have not been on the birds much, but I have plans... always plans and more things to do. I'm sure you know how that goes.
I have had a couple Hustler verticals, generally good antennas. As to your understanding, mine is different. Simply put, the trap will pass everything except the band it is TUNED FOR and designed to trap. It will pass bands on either side, so as far as I know, 40m & 80m should still work.
That said, you mention that SWR is normally 1.2:1 on all bands. Is that a wide dip across entire bands? If so, that is not necessarily a good thing. With a proper ground mounted vertical, first thing is that the normally lowest SWR is 1.4:1 although some tweaking
can get it lower. But the 'dip' should not be terribly wide. If it is, then that likely means a poor ground that is not efficient. In other words, the SWR may be "good" because the antenna is losing power to an inefficient ground setup. Many hams install these antennas on a pipe with no radials (including me early on) and see a nice low SWR across all of the bands and think, 'That's great!'. But alas, in fact no, that means an inefficient antenna that is warming the ground instead of radiating. Adding radials will sharpen the curve and more energy will be radiated into the sky & towards the horizon instead of into the ground.
Sorry if that is more info than you bargained for. Hard lesson on verticals, but your on air performance may thank me later.
73 & Good luck! Kevin N4UFO
