Home
Help
Search
eHam
eHam Forums
Digital
Rtty and Kenwood 990
« previous
next »
Pages: [
1
Go Down
Author
Topic: Rtty and Kenwood 990 (Read 239 times)
W3BJ
on:
January 18, 2023, 10:15:27 AM »
All of a sudden my keyboard has quit working. No rtty and no psk31. I replaced keybord,and nothing I went into menu and usb on front are turned on. I can read rtty and psk but radio won’t xmit. Any ideas would be apprecayed
KC9YAV
Re: Rtty and Kenwood 990
Reply #1 on:
January 18, 2023, 01:12:50 PM »
Have you tried both USB ports with your keyboard? if so then try reloading your settings if you have them backed up on a USB, it is a long shot that this will work. Next do a full reset to factory defaults. I don't recall off hand the procedure but it is in the big manual. I have had to reset my 990 a couple of times when strange problems have occurred that I could not correct by redoing settings. You may also want to check the 990 user group at:
https://groups.io/g/TS-990S
W3BJ
Reply #2 on:
January 24, 2023, 08:40:09 AM »
I did a complete reset on my 990. The usb keyboard started working. case solved. Wrong. Itstopped workingh again. No keyboard on rtty, psk31 or cw. Cant figure this one out.
Pages: [
1
Go Up
« previous
next »
eHam
eHam Forums
Digital
