Author Topic: cheap antenna switcher not bidirectional? or just cheap?  (Read 659 times)
KA4WJA
Re: cheap antenna switcher not bidirectional? or just cheap?
« Reply #15 on: March 13, 2023, 02:39:05 PM »
Jim, et al,
Not to put too fine a point on things, so even dealing in some approx numbers, there are certainly quite a few circumstances where a switch or relay having 60 - 70db of isolation on HF freqs, would still allow enough signal feed-thru to still be copy-able on another receiver or copy-able on the same radio with the antenna switch in the wrong position.
IF the Un-used portS are DC grounded to the chassis of the switchbox, I woulda thought the isolation would be through the roof. Like, just how are you going to hear a signal, any signal, when the center conductor of the UN-used port  is DC grounded ?
That's like putting a shorted PL-259 plug into the back of xcvr #2...with ant connected to the SO-239 of xcvr #1.  You won't hear anything on  xcvr #2.
Another possible option is to try using 2 x ports that are NOT adjacent to each other.... like say ports  #1 and  #3...... or ports  #1  and #4.
If you shorted-out AND shielded that PL-259 plugged into #2, and your antenna feedline was aways away distant (like a few feet), and securely plugged into #1, then you're correct it's unlikely you'd hear anything on #2!
BUT...
But with coax switches (or internal rig switches / relays), we have a different situation.  :)
The RF is flowing just a fraction of an inch away, and since the attenuation / isolation is effecting the signals and noise equally....things are different.
Here's just one example (one that I have experience with):
On 80m SSB, I regularly speak with friends within the state of Florida, most typically within ~ 200 miles, some as close as 50 miles...
And, signals are quite strong, at S-9 +30 to S-9 +40 with most using 1/2-wave dipoles at ~ 50' (at my temp QTH, mine is only ~11' - 15' high....and, I'm still hanging with them)..
(some have pretty accurate S-meters in their ANAN's, and while my old TR-7 needs an alignment, I'm good at ~ 6db/S-unit....but above S-9+20, it gets pretty stingy...)
So, again using approx numbers, with average signal levels of -40dbm (S-9 +33), and a switch or relay with isolation of 60db - 70db (typical of good quality ham switches / relays) we'd still have -100db to -110dbm signals on the other switch ports...
And, that would still be an approx 20 - 30db S/N....approx S-3 to S-4 (with no noise).
{Now my Bird 74 with ~ 90db+ of isolation would put the S-9+33db SSB signal into / near the noise of the receiver at that bandwidth, and might not be copy-able...but if it was CW and we used a narrow rec bandwidth could still be a usable CW signal...}
Remember we are attenuating the noise along with the signal thru the isolation of the switch/relay, and that our HF receivers are very sensitive (in CW bandwidths, with a 3db S+N/N, most have MDS levels of -130dbm to -135dbm.....and in SSB bandwidths, with a 10db S+N/N, most have specs at ~ -120dbm)}
So, if everyone was using a Bird 72, or similar from other manufactures, and signals were more "average" (S-9 to S-9 +10, at best), then it's unlikely that you'd hear anything from the other ports...
But, for the average ham, even using a decent switch, there is going to be some signal available on the other ports... :)
Have a look at some sweeps of my Daiwa CS-201's here:
Re: Share 2 Antennas on 3 Radios?
https://www.eham.net/community/smf/index.php/topic,132604.msg1217846.html#msg1217846
Re: Easy way to keep an antenna analyzer in your system.
https://www.eham.net/community/smf/index.php/topic,136421.msg1264701.html#msg1264701
Re: Antenna Switch Isolation
https://www.eham.net/community/smf/index.php/topic,136487.msg1265278.html#msg1265278
It might surprise some at how good they are (~ 80db+ isolation on HF)....and, while some may wish to tout other brands (yes, I do use a Bird 74 and a 72, as well, for more critical situations), fact is the Daiwa's and Alpha-Delta's are pretty darn good switches for ham radio, and are more than good enough for most hams / ham shacks... :)
I hope this helps some?
John,  KA4WJA
« Reply #16 on: March 14, 2023, 12:35:23 PM »
I still can't fathom the concept of being able to hear anything, with the UN-used ports  DC grounded.
These various switches you quoted..... are the UN-used ports  DC grounded ?
K6BRN
« Reply #17 on: March 14, 2023, 01:15:00 PM »
Hi Keith (N3KXZ):
Just get and use the RIGHT switch and avoid blowing up your radios.  Do NOT be "Pennywise/Pound Foolish" in this case - the penalty is very high.
I suggest Alpha-Delta 2B and 4B RF switches:
https://www.hamradio.com/detail.cfm?pid=H0-008459 (~$90 new, 2-port, OFF/GND position, GDS protection, good isolation)
https://www.hamradio.com/detail.cfm?pid=H0-008461  (~$110 new, 4-port, OFF/GND position, GDS protection, good isolation)
Basic Specs:  1,500W PEP or CW, >50db isolation between ports (about 20dB better on HF), good to ~500 MHz
These are very widely used by hams (including me) for antenna/radio switching systems.  They're reliable, work fine, last forever and often pop up used (and even then aren't that cheap - for a reason - they're very good switches).
Check this YouTube video for safe RF switch use:  "#341: Ham tip: Safely using a coax switch to connect multiple rigs to a single antenna system" by WE2AEW
Brian - K6BRN
« Last Edit: March 14, 2023, 01:22:07 PM by K6BRN »
KA4WJA
« Reply #18 on: March 14, 2023, 05:59:30 PM »
Jim,
Yes, the un-used port is DC grounded.
I realize the old spec sheet is in Japanese.
www.daiwa-industry.co.jp/EN/manual_cs201a.pdf
Sorry about that.  hi hi
(but, I've using these Daiwa switches for decades....and, while I know few actually believe many things posted here-abouts....which is why I posted the real-world sweeps of some of my old --- 20 - 30 year old ---- Daiwa switches....but....here is even more...)
You can look at the specs on their website:
http://www.daiwa-industry.co.jp/EN/products_hamsw.html
Where you'll see the line:
Unused circuits are automatically grounded and cavity
construction.
Or, read the same specs at DX Engineering, HRO, etc...
Or, you can look at the many pics posted online.
Such as this one, showing the inside of the Daiwa CS-201.
http://www.amy.hi-ho.ne.jp/iaasada/restore_other/cs201/cs201-4.jpg
I hope this help?
John,  KA4WJA
« Last Edit: March 14, 2023, 06:01:42 PM by KA4WJA »
