I have two primaries and two secondaries on my EPD.
The question was pertaining to pole pigs.
Lowest secondary, if you are looking backwards from it's intended purpose, that I saw was 7200. And, then you have to rectify that.
Well, I take that back they do have a 4160 several pages in that would be about right.
7200 vac pigs come out to 10,180 vdc no load, then subtract the 20-35 vdc drop from the diodes, and drop across the 50 ohm glitch resistor...then the V drop from the street, etc, etc.
You can get pole pigs in 4160/4800/7200/12,500/14,400 vac.
In this case, they are bought brand new, and custom wound to your spec.
Most 4800 vac pigs also have a 4160 inboard tap as well.
These folks ship all over the country, so the shipping is usually free. If you buy a used pig, then it has to be crated up, and shipping charges.
When I got my 4800, 10 kva pig, (removed from oil), previous ham owner had sliced off the 4160 taps, like inside a bit.
No way could I tap off the sliced off stubs. 4800 is not enough for a 3x6..and too much for a 3x3. So sold the 6700 vdc supply to a local engineer ham buddy, who uses it on his HB YC-156.
Got pissed off, and bought the 253 lb dahl...for $1410.00 brand new, wound to my specs...(+ $225 for shipping).
Ok, now I have a xfmr, that will run anything...and everything.
