No where near an expert here, but I have a system that works.
Inverted L from one corner of lot to a support halfway up the other side of the lot.
GigaParts 31ft push up pole in the corner
84 ft of wire (WireMan 26ga copper coated steel antenna wire), about 30 ft up, and 54ft out to a 15ft re-used TV antenna support on the other side.
At base of pole, 8 radials in a 90 deg pattern, 8-20ft long.
BalunDesigns 9:1 Unun connects antenna wire to radials and feed line coax.
Run of LMR-400 to my office/shack. Line isolator, important to keep RF from shack, then 8ft of LMR-240 to my IC-7300.
Info on BalunDesigns website give best/proper wire lengths for these types of antennas.
Using internal tuner, get low SWR on all bands, except 80M. Use the 'Emergency Tuner' feature in the 7300 to match antenna, but with reduced power <50watts
Works well, have 9 band WAS and 250+DXCC contacts. Not very efficient, I realized, but short of a divorce-inducing tower/beam the best I can do.
Recommend buying a quality Unun. I have several home brew ones, but BalunDesigns worked the best.
Check out their website for information on antennas such as the one I use. A great resource.
www.balundesigns.com
