Author Topic: 14AVQ question  (Read 261 times)
ZL1BBW
14AVQ question
« on: January 22, 2023, 11:02:02 PM »
In the base insulator of a `14AVQ I recall seeing what I took to be a RFC, the one I am going to have to press into service appears to have had this removed/lost/ dropped off.
Is it of any importance apart from the DC grounding aspect?
Thanks
ex MN Radio Officer, Portishead Radio GKA, BT Radio Amateur Morse Tester.  Licensed as G3YCP ZL1DAB, now taken over my father (sk) call as ZL1BBW.
K9RJ
Re: 14AVQ question
« Reply #2 on: January 23, 2023, 08:21:30 AM »
What I remember is that the 14AVQ had a shunt coil across
the base to help raise the feedpoint impedance.  It had more
effect on the lower bands where the antenna was electrically
shorter.
Other than providing a DC path for static discharge, it doesn't
do much on the higher bands.  It isn't really necessary,
especially with a poor ground system where the ground loss
improves the SWR.  But if the SWR is higher than you would
like on 40m, you can add a shunt coil to get a better match,
and it probably won't have a lot of effect on the other bands.
