The small value capacitors have greater 'resistance' (impedance) to RF current. So more of the current is diverted through the parallel high value ones (which present a lower 'impediment' to RF current flow). This is ok but emphasises the need for all components to be able to withstand whatever current/voltage they are individually required to handle.
He installed 5 x identical 100 pf HT-50 caps in parallel. Each of those caps is N750. Each cap is rated for 3.5 amps @ 2.0 mhz. So 5 x 3.5 = 17.5 amps CCS....at 2.0 mhz.
Per Glen's calcs, he only has 4.7 amps CCS (with a 1.5 kw cxr)..flowing through the TOTAL padding. 4.7 amps / 5 x caps = .94 amp per cap...which is only .94 / 3.5 = 26.8% of each caps CCS rating.
5 x 100 pf caps will work just fine. They won't heat....and they won't drift.
On the other hand, IF a single 500pf HT-50 cap was used, those are only rated at 7.3 amps (any freq > 1.69 mhz). They have a worse TC (N5250). 4.7 amps / 7.3 amps = 64.5% of it's CCS rating. The single 500 pf may well drift a bit....and it's C will REDUCE in value as it heats up.... due to it's negative TC.
On any of these doorknob setups, machine screw one end to the chassis. Run one continuous piece of copper strap across the tops of the caps. With 5 x caps, they could be arranged in a row, or a row of 2, and a row of 3.... (rows side by side). Then you have also heatsinked both end of all the caps. That will dump any possible heat, and less heat means less drift.
With 5 x caps, another method is to mount 4 in a square patter, and the 5th cap in the middle. Then on wide piece of copper strap to cover the tops of all 5 of em. Then a 1" wide piece of strap from that mess...off to pad the air variable.
Our local metal shop has 3' x 7' sheets of copper in thickness's ranging from .010" up to .125" . I get em to shear what I want, in any width I want. However, they can only shear the 3' width, due to the 40" max width shearing capacity. Myself, I hate the look of copper, so silver plate....after any trimming with tin snips, and holes punched etc.
