Yes, sealed vacuum relays are a good option. Not always exepensive if you use surplus. I have perhaps a dozen in use outside. I got them from MFJ for less than $20 each I believe. They were Kilovac I believe, and were labeled and advertised wrong, never could get MFJ to correct the error. They were advertised as 12 volt 500 ohm coils. They have 93 ohm coils which works out just right for driving with 6 volts. I tested them on the far end of a dipole as an insulator with a length of wire following. I think I ran 100 watts, so the voltage across the open contacts must have been thousands of volts. So they work fine for a few remote matching networks, etc. at 100 watts. Comercially, we frequently use vacuum relays for various reasons.
Do your own evaluation of the MFJ relays, since I have no idea of the real specs. and have been retired for 23 years and do not have test equipment for evaluation. Dry nitrogen is often used. Also you can get big bags of desicant from Amazon I believe for a few dollars. Rick KL7CW
I bought a dozen of those same kilovac DPST-NO vac relays from MFJ last year. And yes, nine all measured 100 ohms dead on..and not the 500 ohms in their catalog. I had to use my fluke dvm to tell they actually operated. They are beyond dead quiet, totally silent. They were listed as 12 vdc. So used my 0-30 vdc @ 3 amp small lab supply to test a few of em. The pickup vdc was exactly 4.5 vdc. The drop out vdc was exactly 3.25 vdc. They say to operate any vac relay coil at least 20% higher than it's pickup vdc.
They are stupid fast, and then some. Inside, they actually consist of TWO COM contacts. One moves down, while the other moves up..then they smack each other. Noticed there is also an extra in / out wire lead, that has continuity all the time. Apparently it's either a metallic shield, so if several relays were mounted side by side, in a row, and say the middle one operated, the magnetic field generated would not screw up the coil on either side of it. A 2nd function is to bond the shield of say RG-400 going in / out of the relay. Apparently the relay contacts + this shield form a 50 ohm Z inside the relay itself..and the relay just opens/ closes the center conductor.
The rated em at 5 amps @ 30 mhz, per contact, so in parallel, on paper they should handle 10 amps @ 30 mhz = 5 kw.
At 12 vdc, the coil draws 1.44 watts.
Funny thing is, that relay in the mfj catalog is no where to be seen in the KILOVAC website, nor in my high gloss KILOVAC
catalog. I found 3 x similar relays, that look the same in the KILOVAC catalog, but they are all SPST-NO types....and NOT the DPST-NO version that MFJ sells. It's a bargain for $20.00 I would like to know where exactly MFJ / Ameritron used that relay...what piece of gear was it used in ? I can't see it being used for any TR setup, since it's only a DPST-NO and not a SPDT, or DPDT type.
Nobody seemed to know anything about it, or whether it could be used outdoors. Moisture could get inside the hollow assy, upon close inspection. I got em to experiment with. One experiment, I used 2 of em to pad each air variable on a manually tuned, PI tuned input for a big amp. (one kilovac relay with contacts in parallelel per air variable. Each cap is padded with 4 x 500 pf HT-50 caps. (wired both coils in series, and applied 20-24 vdc)
Another experiment is to shunt portions of a hb strap coil on my 40m yagi..to extend the BW. It works, but they are long things. Later switched to gigavac G2 flange types, since they mount vertical. This is in the center of each element, so the Voltage is minimal, but the current is a bunch.
For the price, it's dirt cheap. Did you mount urs in an enclosure
How did u manage to feed 6 vdc to each coil..and keep RF out of the 6 vdc wiring ??
