VE7RF - thank you for the detailed explanation. You cleared up several things that I was unaware of. Since I'm not in a hurry, I think I'll first locate some of the high voltage discs and give that a try. If that doesn't pan out, I have room in the Alpha for four doorknob caps, but size may limit me to using 7.5 KV for those. Someone earlier mentioned the 170 pF HEC doorknobs sold by MFJ in their catalog. I checked the schematics of the AL-1500, etc. and they use two of those as padders in those amps. I suppose I could use two of those and that might get me close enough.
In another thread here, we were discussing a problem I had with drifting padder caps in a homebrew L network tuner - I used a 470 pF doorknob. I replaced that with five 100pF N750 doorknobs mounted exactly as you described and that completely solved that problem.
Thanks again for your assistance.
73, Floyd - K8AC
Those HT-50 doorknobs used to be rated at 5 kv. Several years ago, (like 15 years ago)... HEC upped the rating on em to 7.5 kv.
MFJ sells both the 170 pf and also the 500 pf versions in their online catalog. (google mfj catalog) . I bought 20 of their 500 pf caps..and they all measured 500-502 pf. The 170 pf versions are within 1 pf.
The 170 pf doorknobs will handle 5.8 amps @ 2.0 mhz. 2 of em will work nicely..and provide for 340 pf of padding.
3 of em will provide for 510 pf of padding..and will also work. You have to be careful with padders, if you use too much, they will work fine down at 1800 khz.... but might be too much padding up at 1999 khz. You don't want the tune cap to be at min C when at the upper end of 160m band.
On paper, 2 of em should work. Current wise, it's almost a wash whether 2 x 170pfs are used.... or 4 x 100 pf's are used.
2 x 170's are good for a total of 11.6 amps. 4 x 100 pf's are good for a total of 14 amps. Price is the same on both types....and both are N750. 4 x 100 pf's would cost double the money vs 2 x 170's.
On a side note, the cheapest place to buy HEC caps...is right from HEC. They also offer bulk qty discount pricing, when buying more than a few of the same type. (a helluva lot less vs RF parts). MFJ is priced in the middle and always has em in stock.
The chinese 100 pf caps in 20 or 30 kv will probably do the trick. They are huge things. GL with the project.
