YouTube clip of three separate ID's in English from Radio Europe, a low power* broadcaster in Holland on 6130 kHz. Total clip runtime is a minute and a half:
ID #1 at :12 seconds
ID #2 at :43 seconds
ID #3 at 1:07 min/seconds
https://www.youtube.com/watch?v=SBivemuXV38*In their email they stated...
"6130 has a continuous power of 600 Watt pep this transmitter is running in a quiet position can deliver more power."If they truly mean 600 watts PEP - then this would really be about 150 watts AM carrier. Either way they are using very low power for shortwave broadcasting!
These ID clips taken from listening/recording session on Jan 26, 2023 from 05:37 until 7:37 UTC.
Reception was noticeably better on the horizontal NVIS antenna than the vertical
QTH SE USA / Florida
RX Kenwood TS-590
ANT - ground mounted trap vertical / inverted L array over buried radial field ... or NVIS full size 160M dipole
... de WB9LUR
