I have searched this subject, no hits.
If you know of any posts of someone doing this please let me know.
My idea:
I have a 55' towable manlift. I'm wondering about clamping an antenna mast to the operator basket and using the lift as the "tower".
I think I should isolate the mast from the lift and run a robust grounding line directly to earth;
I'm concerned about RF getting into the manlift circuitry and causing damage; the manlift controls are all digital/computerized. Maybe I should disconnect the manlift battery grounds when transmitting to further isolate the manlift circuitry?
I'd have three lines running up to the basket, RF coax, ground, and rotor control.
(I could just rotate the manlift without a rotor but I'd have to leave the radio shack to do it.)
Your suggestions appreciated. Thanks in advance.
