The original cable and length may have serendipitous transformed the impedance of a untuned antenna!
Actually, while the cable length and/or velocity factor does
change the
impedance of the antenna at the feedpoint, it
can't change the SWR if the cable impedance matches your
SWR meter. (There is still the reduction in SWR with length
due to cable losses, of course.)
Basically, the impedance just runs circles around the Smith
chart as you change the cable length, but doesn't get any
closer to the center (lower SWR).
Where you can get that transformation effect is when you
use a feedline of a different impedance - a common example
is a 75 ohm matching section: changing that length will
vary the SWR (relative to 50 ohms) seen at the radio, but
changing the length of 50 ohm cable between the matching
section and the radio won't.
If you do see a change in SWR (relative to 50 ohms) when you
change the length of a 50 ohm feedline to the radio, then
you probably have common mode current, so the outside of
the coax is effectively part of the antenna. In that case, you
have actually changed the antenna length, so it isn't
surprising that the SWR changes.
