Before, when the 3/4" copper water line was intact, I was probably in a ground loop.
How about the fact that your shack is connected to the ground rod outside through the coax AND to the electrical wiring through a three prong plug? Isn't that two paths?
I have often thought, 'Why ground coax outside shack when it's already grounded through the wiring?' But I am no expert on any of this. I just know I have visited another hams shack that had 'extra grounding' that caused a lightning strike to run through his house taking out appliances on it's way to the mains. I'm not sure
anyone is an expert on grounding in reality though... just folks that think they are. I just follow the idea that with grounding, often 'less is more'.
BTW, for NOISE problems, I am a big believer in common mode chokes... coax wrapped through a toroid to be specific. Used to have them on all leads in & out of a remote coax switch as well as at the antenna feedpoints. Because one antenna can pickup noise and have it travel to another antenna through the coax shield, then come right into the shack on the center conductor of connected antenna, even though it was an UN-connected antenna that was actually picking up the noise. Added all those chokes (ten total) things got a WHOLE lot quieter. - As always... your mileage may vary.
As for this particular noise, however it is getting to your receiver front end, best to track it down and kill it!
