Author Topic: Source for bright color coax?  (Read 613 times)
Re: Source for bright color coax?
« Reply #15 on: February 01, 2023, 05:47:17 PM »
Sticky side of the tape faces the cable.
 I'm glad you told AI5BC which side of electrical tape goes face down. He told me in a private message has has been doing it wrong for the past 25 years.
        Tom KH0/KC0W
KE7FD
« Reply #16 on: February 01, 2023, 06:37:35 PM »
Yes, I'm familiar with adhesive tape, and its proper application. I used it once years ago when we ran out of bailing wire and mastic.
My question was centered on the tendency of some adhesives to smear across the coax after a period of time. I'm sure we've all encountered this before. And referring back to an earlier post, I suppose "sticking' with a name brand made in the USA would be the best approach to avoid that problem.
Thanks for the comments guys.
G
« Reply #17 on: February 02, 2023, 04:12:37 PM »
This cracks me right up.   What's next...double sided red tape ?
        Tom KH0/KC0W
KB8VUL
« Reply #18 on: February 05, 2023, 07:24:53 AM »
Most Plenum rated cable is colored orange or something other than black.
I know there is an ORANGE LMR400 and LMR600 Made by Times Microwave.
It is available as 50 ohm cable.  I use it for installs in locations requiring plenum cable.
Not cheap, but not nearly as expensive as RG393 or RG142.
There is also a newer LMR240 that is bright red.  Again, plenum rated.  That might be something to look at as well.
