Author Topic: Exterior HAM antenna  (Read 558 times)
W1JPP
Re: Exterior HAM antenna
« Reply #15 on: February 04, 2023, 10:30:49 AM »
The ground plane is a good choice.  I built mine with an SO-239 and AWG #12 solid copper wire.
I used needle-nose pliers to put a small loop at the top of the vertical radiator so that I can run a non-conductive support line through the loop and hang the antenna from a nail or a limb or whatever.
These antennas work well.
Very slick idea !  Never even thought of the loop at the top concept.  That would be a 'simple' way to get the HB  GP way up high, via some rope, etc, over a tree branch.
I use three methods to get wire over a branch. For up to 25’ I drilled a hole in a baseball, and ran a loop of a zip tie. I tie some paracord to that and do an underhand swing in a loop and then let it fly. Takes a bit of practice.
To go 30-40 feet I have a kids bow from Walmart. Set a fishing pole up to the side open the nail and line tied to end (nock) end of arrow.
For 60-90 foot trees - yes I have some - I use my compound bow and it soars over them. But my home is fairly rural so now safety issues with neighbors.
After the fishing line is over I tie to pull paracord thru
I’ve raised jpoles made with 450 ohm window line and even my large comet gp-6 into trees. They both work great.
« Reply #16 on: February 04, 2023, 11:52:36 AM »
DX Engineering stocks many omnidirectional VHF and UHF antennas from small to tall. Here are three short ones:
MFJ-1740    https://www.dxengineering.com/parts/mfj-1740
MFJ-1754    https://www.dxengineering.com/parts/mfj-1754
Diamond X50A   https://www.dxengineering.com/parts/dmn-x50a
