The two 240-31 cores used in series - each with about 12 turns of the power cord - took out most all noise I could detect.
I compared noise levels in different bands running off my wall power vs the generator. For all intents and purposes no difference. So I was happy. (Compared to the 20 over s9 noise I would get without the toroids).
I did end up adding a commercial (25 dollar) EMI filter just after the toroids. I put that filter into a Cantex pvc box (4x4x2). Just ran the cord on one side made the hookups on each side and out the other side.
So now it’s about 12” of cord from the generator, the two toroids in series, then about 3” into the EMI filter. Then for strain relief I just wrapped the remaining 6’ of cord into a 4” diameter circle and tie wrapped it leaving a 6” pigtail to plug into.
Overall I’m happy that if needed I can use my “cheaply” acquired 800 watt generator to power my rig for portable / remote operations with my noise problem solved.
