I've searched all over for the answer for this very common problem but I have yet to find an answer that works for me.
I'm wondering if anyone has the secret sauce recipe to make a new Yeasu FT-710 AESS play nicely with WSJT-X.
My shack setup as follows:
Yaesu FT-710 AESS
MAIN: V01-08
DISPLAY: V01-06
DSP: V01-00
SDR: V01-03
DST: USA
POWER SUPPLY - MFJ-4230MV
TUNER - MFJ-939 W/Yaesu Interface Cable
WATT METER - MFJ-882
ANTENNA - Chamealeon CHA EMCOMM II V2
MS WINDOWS 11 Pro
OS Name Microsoft Windows 11 Pro
Version 10.0.22621 Build 22621
Processor AMD Ryzen 9 3900X 12-Core Processor, 3801 Mhz, 12 Core(s), 24 Logical Processor(s)
BaseBoard Manufacturer ASUSTeK COMPUTER INC.
BaseBoard Product TUF GAMING X570-PLUS
Installed Physical Memory (RAM) 64.0 GB
WSJT-X V2.6.1 6b6d74
Pics of my settings attached but I've tried endless combinations.
I have found that I CAT Control works perfectly. Receive and decode works perfectly. But like so many others I cannot seem to get transmit audio from the computer to the radio reliavbly. In fact I did have it working for a couple hours last night. It juyst seems to work and I wasn't able to identify what I did to get it working. Then for no appaprent reason it just stopped working as mysteriously as it started working. I haven't been able to make it work since.
I have contacted Ham Radio Outlet and Yeasu for advice, but it has been my experience that community user groups such as this one often have answers that are far better than the vendors. I'm hoping someone has advice they are willing to share. At the very least I intend to document this problem as completely as possible and hopefully that will help lead to a reliable resolution.
I appreciate any ideas you may have.
Thank you!
Matt
KW1CKY
Sorry. Attempts to attach the screen shots of settings have failed. I'm sure I'm not doing that correctly.
