Hello everyone,
Any advice is greatly appreciated on this. I’m about to start installation on my first HF radio and antenna. I have very limited space as we live within the city. Below is a link to an older satellite photo with some modifications. There are a couple of interests that I enjoy, ham radio and hydroponic gardening. The concrete paver section is for our hydroponic garden.
Antenna Placement Photo
https://ibb.co/YWsxVv2My first HF radio is a Yaesu FTDX10. I’m going to put up a vertical Hustler 5-BTV with LMR400 coax. I’ve been told that this will work fine without ground radials in the Texas soil. I’m not sure about that. I have a few questions regarding the placement and possible radials.
On the attached photo, the blue dot is my intended placement for the antenna.
Here are a few questions that come to mind:
- Is the placement too close to the house or the aluminum patio cover? What is the impact of this placement – I don’t have many options on where to put this.
- Is there a better practical location?
- As for radials, I wouldn’t be able to get 360 degree radials because of the house and patio. Would it make sense to still try to use radials?
- If I ran radials, could I run them under the concrete pavers? The radials would be under a thin rubber liner for weed control with pavers on top. Would that impact the radials?
I did consider a roof mount, but I don’t want radials on the roof – and I am concerned about high wind as the rating on this antenna is only 50 mph. I have a chimney mounted Diamond X-300a, which works great. On the ground for the Hustler, I am going to use a tilt base to lower it in inclement weather.
I appreciate all advice and suggestions for this.
Thank you!
