Author Topic: Can I shorten the power cable that comes with the IC-7300  (Read 541 times)
K8OCN
« on: February 07, 2023, 05:49:27 PM »
I am wondering if there is a reason to leave the power cable so long on my 7300?
I run power poles on everything and each output has its own fuse. As long as its fused is it ok to cut the long power cord and make it something easier to deal with?
Thanks
Del K8OCN
WB2AIU
Re: Can I shorten the power cable that comes with the IC-7300
« Reply #1 on: February 07, 2023, 06:01:04 PM »
I wouldn't. No matter how well you plan, there will always be a moment when you need to move the radio and will by hampered by the shortened cord.
Bob
WB2AIU
WA2EIO
« Reply #2 on: February 07, 2023, 06:03:41 PM »
No problem; it may actually help with less voltage drop, although some feel that using the Power Pole distribution boxes and associated fuses actually increase voltage losses.
If you are concerned about re-sale, then get an aftermarket cable to cut and leave the original in the box.
W4AOK
« Reply #3 on: February 07, 2023, 06:23:20 PM »
Connectors are available, so you could make your own power cord and keep the original in case of resale.
W4AOK
K6AER
« Reply #4 on: February 07, 2023, 07:36:31 PM »
W4AOK
I agree. Resale value goes down with a short cable. Also save the original boxes. Radio sell quicker with the original box.
Mike K6AER
« Reply #5 on: February 07, 2023, 10:31:07 PM »
W4AOK
That is what I did with mine. Just bought the components, (considerably cheaper than a new ICOM cord) and made my own custom length (much shorter) cords.
W9WQA
« Reply #6 on: February 07, 2023, 11:14:17 PM »
N7ZM
« Reply #7 on: February 08, 2023, 08:45:13 AM »
     I agree with Mike K6AER. Keep the power cord the original length. Its best for resale plus down the road who knows when you may need a longer power cord.
Ron N7ZM
W9WQA
« Reply #8 on: February 08, 2023, 10:53:13 AM »
HOW DUMB???   JUST CUT THE DXXXMD THING AND WORRY 20 YRES LATER WHEN YOU TRY TO SELL THE OLD JUNK!!!
 you guys want to spend 30 bucks now to save 20 bucks yres away !!1
and the new guy gets 2 cords anyway...!!!
how did you get a license ???
rig could die, get blown up...
waaayyy tooo much thinking going on here !!!
sooo dumb....
VR2AX
« Reply #9 on: February 08, 2023, 11:00:05 AM »
You can shorten it visually by rewinding the cable like it was in the box and extending the extruding part by the amount convenient. Just add the length you need and replace the plastic crimp fastener. No need for cutting and soldering. Or get a PS126. Then you will possibly ask 'can I lengthen the power cable..' Your question is a good one, don't be deflected.
G8FXC
« Reply #10 on: February 08, 2023, 11:18:36 AM »
I usually shorten mine - you could easily be wasting half a volt along it. Remove the fuses too - necessary in a mobile installation, but not on the shack desk.
Martin G8FXC
« Reply #11 on: February 08, 2023, 12:00:21 PM »
sooo dumb....
Implying people have common sense? Is this your first day here?
VR2AX
« Reply #12 on: February 08, 2023, 12:20:22 PM »
British and some other unsuspecting come with a rather large 'filter' in the 12v DC lead, supposedly required under 'international law' which add substantially to the mass of the power cable.
G8FXC
« Reply #13 on: February 08, 2023, 11:52:57 PM »
That's always the first thing to go - I have a draw full of them!
Martin (G8FXC)
W1MOW
« Reply #14 on: February 09, 2023, 07:25:26 AM »
You can buy an aftermarket one on Amazon for $12.88.
(https://www.amazon.com/IC-7100-IC-7200-IC-7300-IC-7000-IC-7610/dp/B07PLSXJ5F/ref=sr_1_3?crid=BNH5KI8TV0O6&keywords=icom+7300+power+cable&qid=1675955992&sprefix=icom+7300%2Caps%2C131&sr=8-3)
Just buy one and shorten it, and get rid of the powerpoles if you're never going to move it.
Gary W1MOW
The fundamental cause of the trouble is that in the modern world the stupid are cocksure while the intelligent are full of doubt - Bertram Russell (1935)
So not much has changed in almost 90 years!
