...As you probably know end feds don't have a celebrated acceptance...
You do need to be careful about generalizing about "end-fed antennas",
as there are several different types with very different characteristics.
For example, the DX Commander and other quarter wave verticals
are "end-fed antennas". So is a 5/8 wave 2m vertical on your car,
or a J-pole, as well as the towers used by most AM BC stations.
The primary differences are the length (in wavelengths), the matching
network used (or lack thereof), the ground system, and how the
antenna is installed. If you pay attention and choose these carefully,
you can get very good performance, or certainly good enough.
Otherwise, you more or less take pot luck as to how well it
fits with your operating style and preferences.
Sometimes the simplicity of a single wire you can use on multiple
bands with little thought is more important than performance.
Others may prefer to optimize their antenna instead. That is
simply a matter of personal preference, of what factors are most
important for you and which ones you are willing to compromise
on. It's your choice, not anyone else's.
