Problem being next to the driveway is you wouldn't want to run the radials across the driveway. The uneven radial field without going over the driveway won't give you the best pattern.
I have made successful contacts with my BTV, setup temporarily with just using a tape measure touching the bottom of the first section and set to 32 ft as a single radial or counterpoise if you wish.
So I would just run one radial away from the driveway for now.
Once you get in the permanent location, 32 radials in the ground works very well for me. Once you change the number of radials you will have to retune it anyways.
