Author Topic: Using Yaesu FAS-1-4R as a transceiver switch (rather than an antenna switch)  (Read 124 times)
F4GFT
I am using an Yaesu FAS-1-4R as a remote antenna switch for many years, and am very happy with the unit. I have another one and wonder if I could use it to switch between two transceivers, with sufficient decoupling to not fry the receiver of the #1 transceiver while sending on #2. I cannot find specs for using this switch as a transceiver switch (rather than an antenna switch). Any experience? I do not run an amplifier, just the stock 100W. If the Yaesu FAS-1-4R is not suitable, what would you recommend for the task?
Andy F4GFT
WA3SKN
ALL ports are shorted(grounded) until a relay operates... so only one radio could be used at a time.
Will that work with your plans?
-Mike.
W3PX
If you had access to a Nano VNA or could purchase one, you could measure the port to port isolation and know for sure.
"So, we just went ahead and fixed the glitch" - Bob Slydell
"I’d say in any given week I probably only do about fifteen minutes of real, actual, work" - Peter Gibbons
F4GFT
Yes, I think so. I would like to be able to use the radio with the shorted port on its port#2 for 6m monitoring (the 6m antenna is some 35ft away from the HF antennas), but that's another story.
>If you had access to a Nano VNA or could purchase one, you could measure the port to port >isolation and know for sure.
I can get my hands on one; I did not know these things also measured isolation. Is it safe to assume that at least 60dB are required? One of the radios is a FT-950; I heard the FT-2000 had a somewhat fragile input stage. The other is a TS-930, no idea about the ruggedness of its receiver.
Andy F4GFT
W3PX
Andy F4GFT
To test the port-to-port isolation of your switch, you would use the Nano VNA to measure S21, transmission between the two test ports.
A 100W signal (+50 dBm) present at one port of the antenna switch, with a port to port isolation of 60 dB, would present a -10 dBm signal at the second port.
Check the receiver maximum input level spec for your radios to be sure.
73 Frank W3PX
