Author Topic: Antenna tuner control cable jack on Icom IC-7100  (Read 104 times)
K7FLI
« on: February 16, 2023, 10:00:18 AM »
Help!  It's probably me overlooking the obvious.  I have a tuner control cable plugged into my Icom IC-7100 that I can get "un plugged".  Any ideas?  What am I missing? :o
K6CPO
Re: Antenna tuner control cable jack on Icom IC-7100
« Reply #1 on: February 16, 2023, 02:28:42 PM »
If you mean the four conductor cable on the upper right rear of the radio, there's probably a latch that has to be disengaged before the plug can be pulled out of the jack. It's probably (I don't own the radio and I'm working off on-line images) similar to the latch on the radio power cable.
W9WQA
« Reply #2 on: February 17, 2023, 05:03:25 PM »
probably  overlooking the obvious.
VE3WI
« Reply #3 on: February 18, 2023, 11:17:32 AM »
The tuner connector on Icoms is a Molex connector.  Look closely and you'll see a little plastic latch on the top that has to be depressed to allow the connectors to separate.
Dave, VE3WI
