My MFJ Hamsticks came with 2 mm Allen wrenches. The fit is a bit sloppy but they work (after all, you're not torquing wheel nuts at Indy!). A 2.5 mm wrench is too big, but if you really want to, you could make one fit perfectly by carefully filing it down. None of the SAE wrenches fit better.
Dave, VE3WI
