Author Topic: Icom 735 display lights  (Read 128 times)
K6RQR
« on: February 17, 2023, 08:29:28 PM »
Hello All -
 Does anyone have any suggestions about replacing or enhancing the backlighting in the Icom 735? I have one I recently acquired and it works fine but the illumination is weak. Any suggestions appreciated. Thanks.
Bruce  K6RQR
ZS5WC
Re: Icom 735 display lights
« Reply #1 on: February 17, 2023, 11:31:30 PM »
 :)If The original lamps are those pea sized incandescent lamps, make up 3 or 5mm led superbright diffused lamps (put series resistor to led and shrink sleeve).(3 or 5 depending what size led will fit into recess.)
Observe polarity and install. I recently did IC-765 meter lamp with 5mm super bright, and dulled the lens with a scotch pad.
Looked really spiffy.
73 de William , ZS5WC / ZS4L
« Reply #2 on: February 18, 2023, 07:44:18 AM »
