I’m new to DMR with a Anytone AT-D878UVII_ HT and following the RT Systems video on getting started
https://youtu.be/w5xrH7urisUI get to the point where I’ve entered my Radio ID, a few chosen Talkgroups and selected/imported 12 nearby (3-20mi distant) DMR repeaters from a RepeaterBook search. The next comment on the video is to try them and find which is the best repeater. That seems to jump over a lot…
Would I want to add them all to a Zone and then associate each with the Parrot TG and then see which works best from my QTH? I’m a little confused there as some sources indicate Parrot is 9990/Private and others 9998/Group. Does it vary with each repeater or will either work for all?
I also note that the RT Systems programmer added those repeaters as TS2 - is Parrot on both TS1 & 2 always?
Thanks!
BRET/N4SRN
