:)Thanks for your valuable input!.
Will look at the GM3SEK spread sheet too.
Yes , these tubes have parasitic suppressors but also have internal neutralization.
Does that mean I cannot add series L?. worth a try if needed anyway.
Many Thanks,
William
The GM3SEK PI / PI-L spread sheet is the gold standard. Everybody's else's version does not factor in stray L and stray C.
When they talk abt loaded Q, the old method that Eimac and the ARRL used was based soley on the C1 portion.
IE: old books said to use a Q of 10. In reality, that equates to an overall network Q of 12.....and an input Q ( C1 end) of 10...and an output Q ( C2 end) of 2. Input + output Q = total network Q.
You want the total network Q as low as possible. Or you will cook the tank coil. On the spread sheet, only the overall network Q can be tweaked, then it spits out both the input + output Q.
The lowest u can go, is = the sq root of the plate load Z / output Z (50 ohms). IE: say a 4-1000 with a plate load Z of 5 k ohms. 5000/50=100. sq root of 100 = 10. Q can't be lowere than 10. You will see this effect when using the spreadsheet. ( it will blank out with rows of ### signs.
I also use the spreadsheet to caluclate PI tuned input networks. Enter 50 ohms where the plate load X goes..and 50 ohms for the output. Problem is, the spreadsheet will not handle 2 x equal X's. The...'fix' is to change just one of em slightly.
IE: 50 ohms on input...and 49.999 ohms on output, problem solved.
Notice on tuned inputs, like 50 ohms to 50 ohms, with an overall network Q of 4, the input + output Q will both be 2.
Jim VE7RF
